who sells or has done a torsion bar delete to coilover on a 15-19 HD 4wd? I've seen a few older body style trucks done and doesn't look much different from the the newer trucks.
why bother,  your killing the resale value and if you drive on the street its hardly worth the effort.
Ride quality that's why. Not concerned about resale value and the truck rides like a pulp wood truck on these roads around here before and after the RC 3.5". Pulling my track machine or boat and hit an Alabama pothole you better be holding on or you're going through the windshield.
  • Haha 2
On 12/31/2020 at 4:28 PM, Woz said:
https://bds-suspension.com/product?kid=723FDSC
Take a look at this offering from BDS. I don’t think it would kill the resale value. Close to 5 large. There are links to reviews. I know the 1500 are coil over and ride very nice.
I saw that. Im looking for more of just a bracket kit without having to fab it myself. Something similar to what atomic fab offers for the older body styles. I already have a-arms/lift so really only need the upper and lower brackets. If I get time this coming up winter I may tear it down, make templates then have the parts plasma cut.
I checked atomic fab out. They only do the 1500 to 06. I wouldn’t think just adding a bracket would be beneficial for 2500, due to weight and plods. Also alignment issues would likely come into play. If it were me I would go with a tried and true system. Especially if the reason for trading out torsion bar is because the ride is rough. That says you are running on pretty rough terrain.
Wonder what wheel size and psi you are running. Also seats can make the ride better. I don’t find my ride bad on 195/60r20 tires inflated to 60psi, 3” RC lift, under stock Denali seats. I like it better then stock.
22x12 American Force with 35x12.50x22 Toyo's. Truck is a denali. Maybe you have better roads?? My buddies high country with same lift I have and factory 20s with 35'' nittos rides the same way. You put a trailer with a load behind them its almost scary at times. I'll mess with it this winter more then likely. I dont have the time to tear it down right now thats why I was hoping there was a kit available.
https://www.dieselplace.com/threads/torsion-bar-delete-coilover.925802/
https://www.performancetrucks.net/forums/gm-drivetrain-suspension-22/ditched-torsion-bars-coilovers-hd-504605/
    Sothpaw27
    Sothpaw27
  • Who's Online   5 Members, 0 Anonymous, 722 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
