started happing recently on 2015 lt with 60k doors will sometimes re lock themselves after i use remote to unlock. if i lock them again and then again to set the security and then push unlock they will unlock. also they will randomly relock while im driving every few minutes. sometimes doors with lock when i park and pull me keys while jm still setting in seat. anyone have these or similar issues?
