No issue, just curious.  Today I had my truck in for a wheel alignment at a popular tire store.  I noticed the rear lights were on while the truck was on the hoist.  When I peeked in later, I noticed the hood was  up.  Everything works fine and I was pleased with the service.  My curiosity now has the better of me and can't figure out why the lights were on or why they needed to be in the engine compartment for adjusting wheel alignment.  One theory I have is that they left the ignition on so the steering lock wouldn't engage and later needed a boost to start the truck.   However, the lights are on auto and I think they would of told me if my battery was weak. Is there an obvious explanation ?
Depending on the alignment machine and lift we would leave the vehicle is neutral because we would roll the vehicle back and foward again for a rolling compensation. From there we chalk the left rear tire and do a caster swing. When doing that the we would put a brake pedal depresser on, start the vehicle, do the swing left to right and center the steering wheel and shut it off.
If the service took a long time because of frozen up parts it wasn't uncommon for it to drain the battery down. The key always has to be in the ignition so the steering wheel doesn't lock.
  • Thanks 1
Thank you!  This explanation fits perfectly with my observations.  I was very impressed with this shop and assumed they had good reason.  This shop was so good they may have burst my 20 year loyalty to Michelin tires!  "All weather"  tires with long tread life warranties are now high on my research list!
Hunter Equipment is in most chain stores and their process/procedures have a brake pedal depressor to set the toe on older equipment and caster sweeps on all of them. Batteries running down is common so jumping to start would not necessarily mean there was anything wrong with the battery.
Hope that helps.
  • Thanks 1
WOW, great explanation.  I would NEVER have known.
This is what makes this such a great forum!  There are so many knowledgeable members like Cameron and Kim willing to share their expertise!
    Patrick Fergy
    Patrick Fergy
  • Who's Online   1 Member, 0 Anonymous, 1,255 Guests (See full list)
