My 17 silverado LTZ has issues with the drivers window and door. Sometimes it does not regognize that the door is open or closed.....The radio wont turn off when the door is open sometimes and at other times the door ajar light stays on, and every once in a while the horn does not beep when locking the doors with the key fob....when I use the key fob and the horn doesnt sound the widow will not roll down. I have rolled the window down and it not roll up for hours.....I get a message quite often when I first start the truck to open and close the drivers window.... took it to the dealer, New window switch, didnt help....Please help!
Edited by [email protected]
I suggest you check the wiring in the door hinge area. Sounds like you have some damaged or broken wires there.
    TopBo
    TopBo
  • Who's Online   6 Members, 0 Anonymous, 655 Guests (See full list)
