I got a pic attached and after a few nights on the google machine can anyone tell me what these steps are so I can buy them? Can’t figure it out. Red truck is a better pic and my RST looks just like the one pictured minus the steps!
Much appreciated!
Have them on my AT4. Only complaint would be the writing on them. Driver side has Sierra at driver door and on opposite side its at the rear door on opposite side. Maybe I am too picky but looks odd.
    • Looks nice. I still have my 2000, 1500. Bought a 2025, 1500 for retirement. Feels solid. These trucks have a bad rap on the internet. My brother has a `24 1500, 5.3 with 52,000 miles. No problems at all. Mine hasn`t either but mine`s only at 12,700 miles. Have seen some of these things with 100,000 miles with no problems.
