My running lights on my left side of my truck aren’t turning on. They work with the blinker and brake but not running. I believe it may be a ground wire but not too sure. Anyone have fixes?
Welcome to the site.
Each person describes things differently, so which lights are you referring too when you say "running lights"? Maybe the "park light" function?
Like when I’m driving and the night lights are supposed to be on, only the right side is on but the left works with brakes and blinkers
Just by looking at the picture, those are not factory tail lights, correct?
Not factory but I switched to factory again and the same problem with factory
What's the model, year, and trim level of your truck?
‘14 Silverado LT
Here is the first thing to check:
Wow feels like I didn’t even search; this video might be the solution thanks man I’ll let you know tomorrow
You are very welcome, good luck.
    contrabombarde
    contrabombarde
  • Who's Online   4 Members, 0 Anonymous, 1,344 Guests (See full list)
    • Still looks like a rivet to me in the pics, I don't see a nut and none of the pics show the head of the screw. But if you says so.....
