Just purchased a 2021 AT4 1500 6.2L. Looking to see if anyone has inquired with a GMC dealer/service department prior to installing their aftermarket catback exhuast system themselves, as to whether or not it would void any part of the truck's warranty. I'm looking to install a Borla system on mine and would just like to see if anyone was given any concrete answers from GMC themselves, before I approach my local dealer to ask them the question myself (although the truck was purchased at a different dealership thats 2+ hours further away).
Thanks in advance.
