At what point do you take truck in for loud lifter noise( every time I take truck in a certain dealership just tells me that whatever issue I'm having that that's just how these trucks run)
I traded truck in got used last year with alot of issues tranny, infotainment, park assist...
I deleted afm b/c it has dual borla exhaust and sounded terrible in v4.
It seams like the lifters are always louder while at idle now, can I run a different oil or additive to quite them down?
I'm sure if I take to same dealership it'll be" normal" as this seams to be there go to thing to tell me since I purchased a extended warranty i feel as tho this is there way of getting out of looking at anything...
The service department told me they want to find and fix issues with vehicles b/c that's how they make alot of money?( Sounds off to me)
Last time there I said I'm taking it to a different dealer, he replied" they will tell you same thing"
Feel like I'm getting run around since I gave them my money for extended warranty?
Its in their best interest to only repair vehicles that don't run properly. This saved that profit they made off the extended warranty. So yea they are pushing you off and sounding like they are trying to help.
You turned AFM off said parts are still there. When it comes time just go all aftermarket parts and be done with it.
Would taking it to a different dealer have better results or b/c I bought extended warranty they'll all try and push me off unless I get a collapsed lifter engine code or a actual part known broken?
So you had a tuner turn the AFM off correct? That means the lifters cam and associated parts are still in the vehicle. And still liable to fail.. Hence loud lifter noises. "If" that is what your experiencing.
I couldn't tell ya how to go about getting GM to fix your issue as I do my own. Even when mine was under warranty. Trust issues...
Sent from my LM-G820 using Tapatalk
So you think it's more noticeable.now with afm delete(8 cylinders all the time) because there all 8 lifters in use all the time instead of 4,8,4,8 type scenario?no engine code yet, may not be broken to throw a code possibly just out of adjustment?
I honestly think it would not of made a difference as the same parts inside the engine are still installed. There are threads here where guys turned off the AFM and still had lifter failures and rightfully so as the parts that make it all happen are still used in the engine.
Like I always say its just a matter of when these fail. Kinda like "Wait for it..."
8 minutes ago, Ltz4 me? said:
So I may just try a new dealer to see if there more thorough and not give me runaround speech... If lifter collapsed will I get a engine code?
I would assume so as the cylinder Associated will not be able to function as designed. As seen in this vid. ? Same thing only one camshaft.
Edited by Snowcamo
I did a full afm delete with non afm cam, LS7 lifter, new trays, new head gaskets, new head bolts, did the oil blockers to save $$$ haven’t had a issue, I got a code that cylinder #7 was misfiring also went in limp mod, I spent about 1800$-2000$ can remember but closer to the 2000$ mark with the new fluids and tuneB83F0054-31B2-4B2C-83D3-72C7102FDD23.thumb.jpeg.838d6db10cdc7e88a970e01b09dbafb4.jpeg
Edited by Frankielozano214
How long did it take you to do?  I got quoted $6700 to install a stage 2 cam with the DOD delete kit at my local performance shop.
I paid some youngster from Fort Worth that worked at the Chevy house, he charged me 500$ for labor plus the fluids (let’s say another 100$) he did it over the weekend at his house. I supplied all my parts, at the time I didn’t want to change the stall if I got a different cam, so I kept the cam close to oem/ factory specs without the afm/dod. Lifter 7# collapsed 2 months after putting 5000$ down on it so money was very tight at the time and didn’t have warranty on it
    TopBo
    TopBo
  • Who's Online   0 Members, 0 Anonymous, 642 Guests (See full list)
    • First off, I'm not trying to just get easy advice/fixes for the issues I've noticed so far.  I'll be combing through the site via searches and such, and if past experiences are any indication, should find what I need.  For the sake of conversation, though, I figured I'd post the handful of things I've noticed in the 12 hours since buying my 2010 SLE CCSB.     Indicator lights: Airbag and TPMS.  The tire pressures aren't reading for any of the wheels, so I'm pretty certain the sensors were either removed, are damaged, or are otherwise inoperable.  I used to mount and balance tires 25 years ago but am pretty much ignorant when it comes to TPMS.  My 2006 didn't have the sensors and this might be the fourth vehicle I've owned that does.     Radio: Rear speakers aren't working.  I removed the driver's side rear door panel and checked the speaker and wiring.  I also removed the sill and b-pillar covers to check the wiring.  A few minutes of Google Fu showed that this is potentially a head unit issue.    Switches: Power mirrors don't turn left/right.  I ordered replacement driver's door switches that should arrive tomorrow.  The windows and locks work but it was only about $20 for all of them.  The driver's side rear window switch lets the window down but won't put it back up.  I think the passenger rear doesn't work at all.  In the coming days/weeks, I'll break out my multimeter to check all of that.   Unknown wiring harness: There's a box attached to the front driver's side of the engine compartment, right where the second battery shelf is located.  There are three plugs, one of which looks like it fits a standard headlight-style bulb (9007 or similar).  It doesn't look like it's plugged into anything.  I'll do some digging and if I don't see anything elsewhere on the site, post some pictures here.   Unknown plugs on brake booster: There are at least two female plugs on the brake booster that aren't being used.  I think it might be a replacement/aftermarket, so maybe those are used for a different application, as there don't seem to be any unplugged harnesses and no indicator lights are on.   Little squeaks when turning: Sounds almost like a bushing around the bed of the truck.  I'll have to pay close attention as I get more familiar with the truck.   Clunk on acceleration: possibly the infamous drivetrain clunk.  My 2006 had it and I'm just not familiar enough with this truck yet to fully grasp what it is.   Anyway, my apologies for the vague and all over the place post.  This truck is new to me, and it's been four years since I drove my 2006.  With 200k miles, I know I'll need to learn this truck quickly to avoid having any major issues, despite being confident it's got much more life to it.  My 2006 had nearly 320k on it when I parked it (nearly 300k of which I put on the truck), and it was still drivable then, though I suspected the head gasket might have blown.  I'd hoped to have that truck back by now, but it's gone forever, as I detailed in my reintroduction thread.
    • Is it an optical illusion in the pic or is the truck really squatting that much horribly?
    • My initial introduction was here.  It's hard to believe that I last posted in February 2013, having just deployed to Kyrgyzstan.  Since then, I've retired from the military and the 2006 Sierra SLT Z71 that first brought me to these pages was lost.  I went forward to Afghanistan in March 2013 and did a lot of sitting behind a computer on brigade staff.  Within 18 months of getting back to the States, I was selected for Drill Sergeant duty, after which I moved back to Virginia (my home state and where I served from 2004-2008).  That '06 Sierra did a lot of driving between Louisiana, Georgia, and Virginia, and ended up with nearly 320k miles by 2022.  By then, the registration had been expired for a couple of years, but the pandemic had all but eliminated tickets for such transgressions.  Admittedly too, I usually drove my wife's SUV or son's car the 2-3 times a week I had to report to work.  Teleworking sure was fun while it lasted.   I started my retirement leave four years ago and stored the Sierra at my sister's house.  A big mess was made when her fiancé passed while she was taking care of business out-of-state in late-2024, and his son pretty much mismanaged everything to do with the estate.  Even so, I was assured that my truck was safe... until it wasn't.  I found out that my truck had been scrapped about four months after the son took over everything.  There's nothing I could do; I'm 1000 miles away and it was technically abandoned property since he'd even trespassed my sister from her own house (she had no claim to it as she wasn't married, and the fiancé was the sole owner).     Anyway, today I got my second Sierra.  This is a 2010 SLE 2WB CCSB with a little over 200k miles on it.  It's got the 5.3L I'm familiar with and should handle what I need it for.  Hauling stuff that won't fit in the Transit Connect (yep, I sold out, but that's the wife's vehicle) and towing a few times a year tops.  The price seemed decent, considering how much people sell their trucks for in the Deep South: $4500.  I've seen similar trucks listed for more than double that.  I got it from a coworker who left his tag on until we transfer the title next week (Louisiana requires a notary for transfers), so I've been driving it all day.  The rear speakers don't work, which is one of the things that brought me back to these forums earlier.  I can't say how active I'll be as a poster, but I'll be scouring the archives while I find out every little thing I can about the 2010s and particular nuances/problems with my truck.   It's definitely not a GMC, but I got another Willys Jeep a few months back as well, so I'm almost at the same place I was when I first joined gm-trucks.com.  My old 1960 DJ3A was sold back around 2010 or 2011; my current Jeep is a 1946 CJ2A.  So, I've got a slightly newer GMC and a much older Jeep.  I kind of wish I still had that F-250 I had way back when too.  The Dakota is long gone and was technically my brother's truck, though I had it registered and insured.  The F-250 had to go when my grandmother's house was foreclosed on due to mismanagement around 2012 or so.     Hopefully anyone that made it this far isn't too annoyed.  I tend to be long-winded, but I'll be doing more reading than posting in the coming months.
