Bulb has already been replaced since the previous bulb had some burn spots.
I added some grease on the contacts and the main connector cable for the right side housing.
I can bump the housing or hit a rough spot while driving and it will start flashing again but 5 minutes later, its back to no flashing.
The front right bulb hyperflashes due to the intermittent rear bulb flashing.
I did replace a brake booster recently and had to disconnect the brake switch and reconnect it.  Would this cause this issue?
I can't think of any other changes recently that would have caused this to start happening.
Thanks,
Brandon
sounds like a bad ground ,or  loose wire , i would start where your working on it first, the check around  lighting  grounds
Traced the ground this weekend, looked like an old hot wire for my camper top brake light that had corroded or making bad ground. I removed it since I do not use the camper top.  Issue has not returned so far
