Transmission Trouble
Hi all.
I just picked up a '77 Silverado 10, 350, full-time 4x4, auto transmission. I drove it home loaded with a HUGE and heavy camper. The truck did great even up steep grades. The next day I removed the camper and now I have no forward gears. I checked the tranny fluid. It took three quarts to return to normal operating range. Still no forward gears.
My first question is, what happened to my tranny? Did I burn it up running it with low fluid?
Next question, if I need to replace the tranny, what years of GM's would be a direct replacement? I'm guessing that the tranny is a turbo 350.
Thanks!
Thanks!
Yeah, you probably killed it. You may have the TH400, but I don't think so. Most likely the TH350. If you're going to replace it, you might want to try and get a 700R4/4L60 instead. It's just a better tranny overall. You'll see some better mileage out of that beast with that too.
Rob
Your best bet would be to use a 700R4, they are basically a TH350 with overdrive, but get a 1987 or newer one because before that they had a terrible reputation for being unreliable.
If you want a heavy duty tranny I would get a 4L80E, these are basically a TH400 with overdrive, only problem is they are computer controlled so being an older truck you would need to pick up an aftermarket computer which is big $$
cheers!
Your truck made it home just fine , drove up on the driveway just fine, went to sleep overnight , and next day lost the forward gears? It's kinda hard to believe...
No symptomes the day before? Hmm...
Check your tranny linkage or better yet see if you can engage the tranny by hand (the little lever on the tranny, oh, and make sure you have someone pressing the brake pedal, or block the wheels, or ... you know ... don't let the truck rol over you while under it) =)
gabe
Gabe,
I know it seems strange. I coudn't really believe it myself. Here's a possible explanation from someone on another forum:
>You very well may have burned out the clutch plates. Once they cool down and >settle back into place, they may not grip again. Usually you have other >symptoms first, like a delay getting into gear after you shift, but if the bands >wear out that could do it. Another possibility is that something in the valve body >is stuck because of the heat. It's really hard to say without tearing it apart.
Make sense to anyone?
--Larry
Yes , it does make sence, and if that is so , what I would do is experiment with the tranny. You would have to take the tranny out anyways so look into a rebuilt kit for it. A auto tranny is pretty simple to rebuilt especially a TH350. All you have to keep in mind is the way you take the old clutch plates out that's the way the new ones go in (in exact same order)
A good candidate for a swap would be a 700R4 'cause it has a OD but you got to keep in mind the t-case adaptor plate to the new tranny, the linkage to the shifter, and now the driveshafts will have diffrent lengths.
So to keep things really simple I would stay w/ the TH350. They are bomb proof with proper maintainence. Sorry I couldn't be more help :(
  • 1 month later...
Keep the TH350/400 tranny. with the full-time 4wd you probably have the NP203 transfercase, and there probably isn't an adapter to fit that to the later model trannys. so you would have to replace that too, & then you would have to replace the hubs to make it part-time 4wd.
    • Great info to have, I printed out what you had in your document as well as Newdudes post as I could see this mistake with the hardware happening very often if not realizing what type of special bolts are being used and just guess on bolt size for torque or the good enough "easy" method as per whack in the used bolts with an impact and send it !.
    • I installed the Auto stop eliminator on my 21 Sierra SLT shortly after I got it. They have a detailed video instruction on how, took me about 20-30 minutes to do. I was apprehensive too to start tearing apart a new truck but it was pretty easy install. Like you mentioned get some trim tools. I went to Harbor freight and picked up a set. If you can find some install videos/instructions to give you and idea for a plan of attack you should be fine.
    • If all oil manufacturers had to meet a higher standard for not just the initial filtering of the oil but that they had to improve on their formulation so that the oil cleaned the engine such as the Valvoline R&P or the new Mobil product ( assuming it works similar of course ), and the oil was changed on an interval based on good UOA data, there shouldn't be any gremlins running around like miniture rats on top of your heads to be washed down into the oil pan below 😁
    • Worst factory HD wheels GM makes
    • A while back on another thread there were comments and thoughts on air filters and I know that can tend to be a bit of a hot topic because of outfits that have a vested interest in selling aftermarket air boxes fitted with the gauze type of oiled elements touting the lower air restriction. However and unfortunately I don't know where I have seen the test results in the past about the amount of dirt through a test procedure that these style of filters do pass more dirt through than a properly designed ( not some cheap Chinese knock off ) paper/synesthetic media filter can do. Lake Speed had a conversation on that topic with one of the employees at Donaldson and there seemed to be a consensus of these oiled filters falling short in the absolute percentage of dirt holdback.    Which all ties back into how good the air filter is on the engine at keeping dirt out as that is going to reflect as a contaminant introduced into the oil as well as cylinder wear even if some of that dirt does find its way out of the exhaust rather then the crank case. Put another way that one can throw the kitchen sink at filtering the oil and using a bypass system which I fully expect will do nothing but good for the oils contamination but if the air filter system isn't doing its job then its preventing the engine from reaching the best wear/lasting case scenario instead.    Now perhaps this topic is or isn't for this particular thread but Grumpy Bear or anyone else for that matter, do you have access to some scientific trust worthy testing on engine air filter types to get some proper comparison data to post up.
