I posted this in the Mod board but haven't had any responses so I thought I would try here as well.
I have a 2020 Silverado WT provided by my company.  My 2016 had a 3.5MM audio plug in the center console and I had a Sirius radio that I connected that way.  Chevy has stripped these trucks way down and no longer gives you a 3.5MM jack (or any storage for that matter).  The Sirius radio came with an FM adapter that goes in series with the normal FM radio antenna which then allows you to tune to a station on the radio to listen to the receiver.  I located what I am pretty sure is the antenna connection behind the passenger dash below the glove box.  I don't know how to get the cable out to see if it is the same style as the Sirius adapter.  In the old days you just pulled hard but this looks like it may have a captive plug that needs to be released but I can't see well enough to tell.
I found a picture from back in 2019 on this forum that has a good image of the unit,  It's the black coax that I assume is the FM antenna,
Can anyone tell me what has to be done to release the cable?  Thanks in advance.
Looking at the pic, you'd have to squeeze the black tab on the back of that cable while pulling it out to release it. The pic doesn't show much of that black tab. They're could be a red or white plastic tab inside of it at the very end. If there is you'll need to pull that down first to disengage the lock so you can do the first thing I said. I've found fingernails aren't enough to pry a locking tab down. You'll need a pick or some other tool to help out.
    • Some clarification may help with some of these issues.   - Rev Industries is/was the division of BAK (now Realtruck) that makes covers under the OEM names.  So if you see one with a Ford logo on it, or if you are buying the GM Accessories cover, you are essentially buying a BAK G2 cover with different branding.   - Rev Industries now markets under RealTruck "Advantage."   - As of May 1, 2025, the Advantage covers now have a 5 year warranty.  Anything before that was a 36/36K warranty.   - Parts for the covers are available from Realtruck or BAK.  The email address to reach them is [email protected] or you can call them at 818-365-9000   - If the entire cover has to be replaced, you have to go through your local GM dealer.  Service dept opens an RO, notes the damage and submits it as a warranty claim.  Keep your paperwork handy so they can confirm when you purchased it and it's within the warranty timeframe.  Once the warranty claim is approved, Parts orders the replacement cover.  When it arrives at the dealership, service will remove and install the new one for free as labor is included under warranty.   - The Advantage covers are not the latest and greatest Gen 3 covers.  They still use the old school clamps, elevator bolts, etc...If you want the newer technology, consider buying your cover in the aftermarket world.  That way, if you have an issue you can deal directly with the manufacturer.   - Finally, RealTruck has a program with many of their authorized dealers that doubles the warranty to 10 years if the authorized dealer does the install.     Hope this helps.
    • Welcome to the group!  My '22 just crossed 150K miles.  Runs perfectly.  Oil pump belt will be done in the next 30 days or so and onward hopefully for another 150K.  Love the truck.
