Not too long ago I had a message pop up on my dash that I had a right front turn indicator failure. So naturally I changed the bulbs, both bulbs were in good condition but I changed them anyway. After the fix, I tested my turn signals and the same message appeared and still no lights. I have checked fuses and can't find anything that can lead me to the issue. Left turn signal works as it should but still having problems with the right. Could it be a grounding issue? Wiring in the whole headlight assembly? Frustrating and want to fix.
On my 2017 Silverado it was a wiring harness issue.  Warranty fixed it.  Can't tell y'all what harness they replaced.  Probably from the bulb back.
Jim
  • 3 years later...
Depending on the bulbs, incandescents can burn out slowly giving this indication
    nolankd
    nolankd
  • Who's Online   3 Members, 0 Anonymous, 304 Guests (See full list)
