I’ve been having this problem lately where the recirculating button doesn’t light up and the other one next to the A/C start to blink any suggestions on how to fix?  Sierra denali 2017
    • probably won't get a response from that user, as they haven't returned to the site since making that one post.  users don't (at least I don't, and I haven't seen any setting which would notify me via say, email) get any notification other than going to this site, and checking if they got a response on their thread...
