Slight problem...need advice
Well guys, as in my previous post, my 3" body lift, ford torsion bar keys, and 315/70R17 tires went on my Tahoe last week. Everything is great except for one problem I tracked down today. It seems under heavy acceleration while turning and when going over light dips/bumps the rear tires are hitting a rear suspension member.
I know this probably isn't the best solution but is there a way to use spacers to move the rear wheels out between 1/4" and 1/2"? Is there such a spacer made? What about using something like a thick washer? Like I said, I know it probably isn't the best solution but all I need to do is move the wheels out between 1/4"and 1/2" and they will clear the suspension member. Any other ideas?
Thanks,
B.J.
Well, I solved the problem last night. I took off the rear wheels and looked around at what they were rubbing on. I had bought some washers and was going to use them to space out the wheels but after putting them on and bolting it up I didn't feel like it was a safe solution. That is when I busted out the dremel tool. After some cutting and grinding I have no more rubbing problems!
It rained off an on all weekend so I didn't get a chance to wash it and take some photos. Hopefully sometime this week (or maybe Friday/this weekend) I will get some pictures.
Thanks.
B.J.
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
    • Too much voodoo and snake oil.   Time to go EV    😉
