Shock recommendation
I have a 99 Silverado 2500 4X4 EC with 50,000 miles.
I tow a boat and have a slide in camper I use in season.
I put on Firestone Air Bags last year, keep them at 10psi when not loaded.
The shocks are all original- they feel good still.
Question is, when to change? And what recommendations for heavy load carrying when I do change? Thanks.
I went with BilsteinHD at 40K on my Tahoe. After putting those on, they made me realize the stock ones were toast.
    Brendan C
    Brendan C
  • Who's Online   4 Members, 1 Anonymous, 1,194 Guests (See full list)
