I just got my 2021 Trail Boss Custom. I built a under seat cargo organizer of sorts and plan on putting a dual USB port receptacle in the center of it so the kids in the back can plug in phones.
I was thinking I can run a wire up to the passenger side fuse box and tap into it somewhere. Any suggestions on where to tie in power?
I want power to the usb receptacle only when truck is running.
Any help is greatly appreciated!
In the passenger side fuse box you will see a blade next to a 30-40 amp fuse. It is if you want to have the 12 volt  hot constantly or move it over one to run it with acc. or ignition power. I ran a wire tap from that for a camera display.
Edited by Camaromoe79
