OK so i have a 2009 GMC Sierra 1500 king cab.
The drivers door power windows control switches will:
1. Lower the 2 rear, but will intermittent roll them up with much fuss with buttons.
2. Will roll up passenger door up, but not down (I hear the clicking, but not action).
3. Rolls the driver door up and down like normal.
The passenger door window switch will:
1. lower window, but not raise it.
The rear doors each window switch will:
1. lower them, but not raise it.
Is there all defective switches? Or is it all based on that driver power windows switch.
Suggestions appreciated.
P>S> the windows roll up and down with normal speed, when they work LOL
sounds like a bad connection issue, possibly a ground issue. Only way to be sure is to remove the panels and clean up the connections, check for corrosion, and possibly low volts. Start with the drivers door, and with the panel off and having cleaned the connections see if it helps your issue, if not move to the passenger door, and clean that one, then once again check to see if the issue has been resolved.
If you have to replace either door switch assembly, it will have to be programmed to the vehicle if it is new.  If buying used, get one with the exact same options as your CREW CAB, lol.  There's a company on Ebay that sells the factory switches in white boxes, from same factory in Mexico that makes them for GM for about $7 each.
They do not require programming. I have personally changed 15 or so. Plug and play.
45 minutes ago, JohnnyGaloshes said:
I took the driver door and passenger door switches apart, cleaned the terminals and it works like a charm. Thanks gang!
No problem. That's why we are here.
    250.6k
    liddlera
    liddlera
  • Who's Online   2 Members, 0 Anonymous, 715 Guests (See full list)
