I have a 2018 Silverado single cab with a supercharger and tune. I tried having a new key programmed and it put the truck into a learn mode and now it won't come off. Dealer says I will have to have BCM and ECM flashed which will reset everything to factory meaning my tune would go away and truck won't be drivable till I get a tune put in. Any other suggestions??
Well, you could either purchase the dealer level hardware and software and see if you can fix it yourself.  Contact WAMS (White Automotive) and see what they suggest.
As for your tune stored in the ECM, you should be able to save it with an AutoCal or something similar.  I'm not up to date on K2s but you can check BlackBear's website.
    • On 2021 3500hd it consistently sets automatically when selecting park if the incline/decline is above a certain angle.
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
