Thanks. On my suburban there are no external trans fluid lines. From what I can deduce by exploring different radiators for the 2018 suburban, there is the high capacity towing package which includes transmission fluid cooling and engine oil cooling via a single high capacity radiator. Without the high capacity towing package the radiator only cools the engine oil. Basically this is what I want to confirm. Really trying to determine if any 2018 suburban cooling system came from the factory with a cooling radiator that is external to the coolant radiator.
I have 2018 Suburban with 6L80 Trans and 5.3L engine. I am chasing a high temperature problem for the transmission. I am wondering if all such suburbans have passages in the radiator to cool the transmission fluid. I was trying to get a temperature reading with a infrared temp gun off of the trans lines into the radiator and could not find the the trans lines into the radiator. I know that on some 2018 suburbans there are trans lines into the left side of the radiator, but I can't find such lines on my Suburban. So what I am looking for is definitive confirmation that some suburbans do not have transmission fluid lines into the radiator.
I thought that about "vintage" edition Broncos. Put some $40 steel rims on a Bronco call it a vintage edition and you can charge 28 times the actual cost.
