Does anyone have any picture of their Denali with the Rough Country 3.5 level/lift with the UCAs?  I traded in my 2019 which had a 2" level kit on it, and even with stock wheels I always felt I should have gone bigger.  So, now I have a 2021 Denali, and am looking at a 2" level, and the RC 3.5 kit...but I'm a little concerned that it's not going to look right if I keep my stock 20" wheels/tires?  Does anyone have any pics of a Denali with this setup?  I tried searching, but couldn't find what I was looking for.
  • 2 months later...
