Seeing as how I’m having a hard time finding an LT 2500 with leather, I was wondering if anyone could confirm that Katskinz makes a kit for these trucks with the seat back storage for the second row. I used Katskinz in my 17 f150 and loved it so I know they make a great product. Thanks for the input.
I don't know about the 2500, but I had Katskinz put into my 2020 TrailBoss LT and the seat back storage is leather.
  • Thanks 1
Thank you. I’m fairly confident the 1500 and 2500 share all the same interior and this forum is a bit more active than the 2500 mod forum so I posted here hoping to get a quick response which I did. Thank you. I just wasn’t sure if they had a kit that allowed for that little storage door in the backrest but it looks like they do. Thank you.
    • On 2021 3500hd it consistently sets automatically when selecting park if the incline/decline is above a certain angle.
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
