Does my 2016 suburban LS have wiring already set up if I want to add factory fog lamps or do I have to purchase a harness and connest Thank You.
Welcome to the site.
Part 1 & 2.
  • 5 months later...
From what I have been able to find so far, original parking sensor and fog harness PN was 23187813 which superceeded to 84307173. This is turn *should* be plug and play into the OE harness (Seemingly). Then you would need to buy an OE headlamp switch which has the fog function, verify the wiring from the switch to the BCM. You would need to find someone who had the ability to change the function list in the BCM to "open" or allow the fog lamp function. That would make it as OE as it gets...
The videos above are a much cheaper and quicker alternative.
    Brandon 29
    Brandon 29
  • Who's Online   1 Member, 0 Anonymous, 342 Guests (See full list)
