Hello all
i have a question about engine cooling on these trucks... might need a new radiator. idk.
2004 sierra 1500 4x4 5.3
scenario 1- sitting in the shade with the AC on during 103 weather.... engine reached 230. had to shut the AC off and drive the truck to cool it back down.
scenario 2- tuck pulling a 5,000lb trailer up a hill at 3,500 rmps 60mph.... truck reached 230, then cooled back down once the hill was taken and started cursing again
scenario 3- going 90 mph at 3000 rpms with the AC on and 90+ degree heat outside..... truck reached 230, shut off ac and slowed down to cool engine.
someone USED to make a high flow racing thermostat housing for these engines... but i think the rona & CA laws killed them....
but does this sound like a radiator issue?
water pump works well. only 1 year old.
fan clutch is good.
how can i make this engine stay at 180. period. ???
so you might want to replace your thermostat, and since you will need to drain the coolant to do so, go ahead and flush your Hvac w/ a garden hose on light water, putting the water through the return, basically reverse the way it would normally flow. Then Also flush your radiator with water.  Put everything back together, and be sure to bleed the system very good.  Dont lose patients on the bleeding procedure.
Put in a lower temp thermostat and wash the A/C condenser and the radiator to clean out all the fins.
Iron block? If so feel the bottom of the radiator.. and check that it is not solid with rust from the engine collecting there..if it is clogged it will be cooler than the top half of the radiator.. then replace it.
Edited by PPK
    Sothpaw27
    Sothpaw27
  • Who's Online   2 Members, 0 Anonymous, 546 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
