Can someone tell me if the 17 Canyon SLT crew cab is wired for a GMC Kicker subwoofer under the back seat ???
  • 1 month later...
    President Roberto
    President Roberto
  • Who's Online   1 Member, 0 Anonymous, 298 Guests (See full list)
