2015 Silverado 2500 Double Cab w/6.0
the issue is that every once in a while, when I start the truck, it won’t start and the Theft deterrent light comes on.  If I turn the key off and try again, starts fine.  Also, this happened once. I turned off they key and s as lol if the electronics shut down (radio. Dash lights, etc.). Truck would not start, no dash lights and a clicking sound.  Jump started the truck snd everything was fine again.  I have a work badge with a chip in it but, I put it in a sleeve to prevent miscommunication.  I’m thinking it’s either my key or the theft deterrent system.  Thanks got your help in advance.
I've had something similar happen to me. Turns out I had a buildup of lint in the groves of the key. Cleaned it out and all good. Sounds crazy but it worked.
    • probably won't get a response from that user, as they haven't returned to the site since making that one post.  users don't (at least I don't, and I haven't seen any setting which would notify me via say, email) get any notification other than going to this site, and checking if they got a response on their thread...
