That stinks. Iâm sitting on the side of the road right now with the same issue. Never had an issue before taking it in for the ground strap recall. Now Iâm outside of warranty and theyâll probably want $200 just to diagnose what they already âfixedâ.Â
âIt should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumerâwe talk about a fuel saving of ~âŹ100 compared to a risk of âŹ1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1â2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.â
Â
I liked this and the following paragraph as well but itâs really only touching the beginning of the benefits OEMs see from specâing these oils. After you factor in âout of warrantyâ service work and new car sales when these engines fail before their time, itâs a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
SwRI is who the big OEM's go to for this sort of thing.Â
Â
Â
In the above the ring and bore plus valvetrain power is roughly the same for 0W30 to 0W16 but both fall apart in the 0W8. Overall the only looser is bearing friction which Stribeck told us decades ago.Â
Â
There is much to ponder in that reference material. That was a good find @OnTheReel
Register a new accountSign in
