Anyone installed a cb radio in their 2019+ truck? I’m trying to find a location and looking for ideas.
I recently installed an amateur radio (Yaesu FTM-400XDR) in my 2020 TrailBoss.  I installed it near the tire jack underneath the right rear seat and ran the wires through a knockout in the floor right beneath the jack.  One cable to the rear for the antenna and power wires to the battery.  Inside the cab, I ran a mic extension cable under the carpet and came up next the console on the passenger seat side.  It wasn't that difficult of a job, and looks very professional.
