Need Some Tires?
Just trying to gauge if there is any interest out there in buying the stock tires off my 3/4 ton Avalanche. 245/75/R16 Load Range E, They're the all terrain Firestones. Got about 3,800 miles on them, no defects. Looking to put on bigger meats. If interested, what would you think is a fair deal?
Gunslinger
