I have a 2021 3500HD SLT Gas. I’ve read the manual, which says you can shift into L at any speed, and then use the + and - switch to set the highest allowed gear within limits set by the transmission computer.
When I’ve tried it at low speed, the transmission downshifts to the lowest possible gear for the driving speed. Is that what happens if I was to shift into L at 60 or 70 when starting a climb?  Shifting down to 3rd or 4th and 4 or 5k rpm, or does it stay in the current gear until you set a lower highest gear? I’ve been too cautious to try it.
At higher speeds it stays in the gear it's in when you shift to L.  You can then drop that gear by hitting the "-" button, but only if the computer agrees you will not over rev by doing so.
Shifting to L from 5th or 6th gear will drop it to 4th.  Has been this way for quite some time, at least 2015 on the HDs.
So those two answers above provide conflicting information.  Do you know which is correct for a 2021?  I’ll ask the dealer, but I’m not sure if I can trust their answer given their track record on technical questions.
@newdudeis correct. I use L often during my daily driving just see if it makes any difference in milage. Such as allowing the truck to coast rather than downshifting. At normal speeds 50-60 mine always shifts to 4th. Lower speeds it usually drop 1 gear below the current gear in use.
Here is the chart that the dealer would pull up.  They used to put this in the owners manual but not sure if they still do.  2014 1/2 ton trucks was the first time GM did it this way, followed by the HD in 2015 and they've been that way since.  The 2007-2013 trucks if you went from D to M it wouldn't downshift.  It would indicate "M6" or whatever gear you were in.
Quote
In vehicles with gasoline engines, when the shift lever is moved from D (Drive) to L (Manual Mode), a downshift may occur. The gear that the transmission is operating in when the shift lever is moved from D (Drive) to L (Manual Mode) determines if a downshift occurs. See the following charts.
6-Speed Automatic Transmission
Gear before shifting from D (Drive) to L (Manual Mode)
6th
5th
4th
3rd
2nd
1st
Range after shifting from D (Drive) to L (Manual Mode)
L4
L4
L3
L2
L2
L1
8-Speed Automatic Transmission
8th
7th
6th
5th
4th
3rd
2nd
1st
Range after shifting from D (Drive) to L (Manual Mode) – Tow/Haul not engaged
L6
L6
L5
L4
L3
L3
L2
L1
Range after shifting from D (Drive) to L (Manual Mode) – Tow/Haul engaged
L6
L5
L4
L3
L3
L3
L2
L1
10-Speed Automatic Transmission
10th
9th
8th
7th
6th
5th
4th
3rd
2nd
1st
L7
L7
L7
L6
L5
L4
L3
L3
L2
L1
L7
L7
L6
L5
L4
L3
L3
L3
L2
L1
Edited by newdude
Thanks everyone, and thanks newdude for posting that chart.  That answers my question clearly.
I stand corrected. Not sure what I was doing that last time I shifted to L, but just now it behaves like the table says.
    mighty K20
    mighty K20
  • Who's Online   3 Members, 0 Anonymous, 420 Guests (See full list)
