Hey everyone, been having an issue lately that has only arose after me doing preventative maintenance (go figure) hopefully someone can confirm what im unfortunately hypothesizing😭. Been creeping the forums for years, but first time posting a personal issue that has me stumped.
Buckle up, this is going to be a long one.
i’ll start off with the basics, 2002 GMC Sierra Denali 6.0L AWD. 254xxx KMS
if this is posted in the wrong section i apologize and feel free to move it where it needs to be.
a week ago, i replaced all 4 u-joints under the truck with quality spicer replacements (due to getting a small cyclic squeek under the truck when moving)
(note: both front and rear driveshafts are ONE PIECE)
after the successful replacement of the u-joints, the cyclic squeak has disappeared. Score.
However right after the repair, i  developed a horrible grinding /vibration sound in the floor when i slam on the brakes from higher speed.
also have a slight vibration now when driving at certain speeds.
Note that this noise/grinding/vibration was NEVER PRESENT for the 75,000kms ive owned the truck, before i did the u-joint replacement.
never there until i replaced the u-joints.
so like any rash human being, i took both driveshafts into a driveshaft shop to get them balanced thinking that was the cause.
well the driveshaft shop successfully balanced both shafts and they double checked my u-joint install. Everything checked out and good to go.
re-installed driveshafts and the noise/vibration is still present during hard braking and small driveline vibration at highway speed.
I’ll start off by saying NO, please dont tell me its anything to do with the brake system. They were all replaced 6 months ago. All rotors, all pads, all slides properly lubed and all calipers checked for proper movement/seize. The vibration is NOT in the steering wheel or brake pedal when braking. And i never had an issued slamming on the brakes for the last 75,000 kms, never had a vibration or noise until i replaced the universals.
so ive ruled that out.
next is the wheel bearings. Ive jacked up both axles and checked for play on all 4 wheel bearings. Solid. Not a single MM of play to be had.
so wheel bearings are out.
which brings me to the death blow.
this is what im unfortunately hypothesizing and im hoping someone can chime in.
About a month ago i had a leaking rear output shaft seal on the NP149 transfer case (AWD),
no big deal i thought. Bought new seal and installed. Good to go no more leaks.
but when i installed my newly balanced driveshafts from the shop, i noticed the rear output shaft of the TC, i can push up and down quite a bit and minimally side to side. There is play there thats not normal. If i push the output shaft hard enough upwards i can get a “click” sound from inside the Tcase as well.
i would say roughly 1/16-1/8” of play up and down with the shaft.
This isnt normal is it?
which is where ive drawn the conclusion that my new u-joints on the rear shaft have tightened the slop in the driveline. The grinding/ vibration when slamming on the brakes is from the slip yoke sliding into the transfer case with momentum of the harsh braking, and putting pressure/pushing on the worn output shaft busing/bearing of the TC, giving me the horrible vibration / grinding. Does this sound like i could be correct?
It would make sense that the output shaft bushing or bearing is toast since that output shaft seal started leaking a month ago and i replaced it.
but what doesnt make sense is why didnt i have this grinding/vibration with the old u-joints and out of balance drive shaft for the last 75,000 kms?? 🤯🤯🤯🤯 why was it quiet as a mouse and now new universals and a balanced shaft has brought out a hiding demon?
anyways just looking for some input, probably need a TC rebuild from what i can decipher, but that can be quite pricey. Might get a used TC out of a wrecker. But any suggestions would be great! I believe ive located the issue but i’d like some others input.
thanks everyone.
-DenaliGuy93.
Edited by DenaliGuy93.
Years ago I went to GM's dealer training classes, 4 wheel & all wheel drive class was 1 of those classes. I'm sorry to say they did not cover trouble shooting so much as how it works, they pretty much referred us to the diagnostic charts for trouble shooting.
It seems to me you've hit the proverbial nail on the head. When ever a seal goes bad you can figure the bearing behind it is toast too; it could be the reason the bearing went bad, too much slop in the bearing caused the seal to go outta round, thus leak.
 I'd get into the case before you run out and buy another, it could be it's just the output bearing but that's  not how things usually go. Buying a T case off a wreck could give you the same problem (or worse) you have now.
As Like to tell people looking at a high cost for a auto repair: You can do a lot of maintenance (if you're doing the labor of not) for what a car payment is; esp. these days.
Monstertransmissions.com lists a new NP149 for $1,295.00. Over haul kits are available from them for $84.00 and the master kit for $194.00 but neither comes with the chain, they will be happy to sell you a chain for another $144.00. I suggest you shop around; I saw kits on Amazon.com. Apparently chains don't typically come with the overhaul/rebuild kits. On Amazon they have new case halves with bearings installed. I punched in "NP 149" and came up with parts for it and forum articles you might be interested in reading.
Looking at the auto parts dealers i sure as heck wouldn't be going to them, Monstertransmission.com looks like a screaming deal in comparison.
Would love to read of your success!
Good Luck!
Doug
https://automotix.net/usedautoparts/2006-chevrolet-avalanche_1500-transfer_case-inventory.html
Edited by dna9656
    • While you are waiting on parts...   On my last few vehicles I've been installing full ceramic UVA/UVB/Infrared blocking window tint even over the solar glass my 2015 was fitted with. At high sun angles on cloudless days this is HUGE reduction in compressor load (interior heat from radiation) and your personal comfort. The new generations of Refrigerant are not as efficient as they once were.    I can't see my breath (meat locker style) but I can run the system on very low settings on very hot days and be quite comfortable. It keeps up well and if you use the recirculation until cooled down, it does so fairly quickly. If ultra humid stay in recirc. The blend door has a minimum; you won't suffocate.
    • Pryme ! I was thinking of adding one to my 2024 6.6 gas  . Could you elaborate a bit more on your statement  Thank You
    • What a wonderful result! Great story telling to. You are quite multifaceted sir.  I'd keep it. Four is my limit too and yet we have five as well. One assigned the 'salt car' to do all those tasks you hate to ask of your 'Save for Good" crowd. 😉    Don't forget the antifreeze.    The Iron 4.3 is a favorite of mine.
    • Thanks Buck Wallace ! The more owners that tell me they are getting the same noise the more comfortable I will be with it !
    • Ancillary parts to the lower intake and connections went together without issue.   There was a brief pause when I leak-tested the fuel lines and injection system. Fuel was spraying all over. Lovely. O-rings weren't sealing the fuel lines to the spider, and inbound line was leaking at schrader valve, leaks at both flange nuts. It's moments like those when you just want to set fire to the whole shop, and be done with it. I was mostly enjoying the project up until that point, and was tracking to an agenda of having a running Blazer and a cold beverage in hand by dinnertime.    I found some larger Viton o-rings for my spider and some grease to get them to seat. One leak solved. Swapped fuel line Schrader core for old core. Still leaked. Swapped entire valve for old valve. Leak solved. Nudged the flange nuts a little tighter on the connections. Another leak solved. I could cycle the key / prime the pump and the intake was staying dry.    Reassembled the upper intake, with 10,000 vacuum lines, and filled the cooling system with water* (this is temporary, I'm not done with the cooling system yet).   Showtime!!   Cranked it over and smoke billowed, it was running rough. CEL illuminated and began flashing. P0300 and I somehow tripped a code for the TPS sensor, voltage low.    There's nothing as unrewarding as a vehicle that won't run (and produces the same code/problem) after hours of research and work.   Clearly I was in over my head. Was the timing off, did I stab the distributor incorrectly? Is the new distributor bad? With my limited OBD 1.5 data stream I really don't have a lot of parameters to see. The engine was pulling mad timing again (flooding?).   Think, Atlas, think.   1-6-5-4-3-2. One, six, five.....four, three, ....two. Wait a second. That makes no sense. 1 is the forward cylinder on the driver's side, so 2 should be the forward cylinder on the passenger side, not 6.    I can't believe it, but I'm looking right at it. Swapped 2 and 6 on the distributor and turned the key over, and...   It fired, coughed and stumbled, smoked, and then settled into a smooth idle. The scanner showed no codes, no lights on the dash, and the throttle was nice and responsive to gentle revs while it warmed up.   It's working!!! IT'S WORKING!!!   I paused for a late dinner, no cold beverage yet. I was determined to do my shakedown run. Did a basic safety and fluids check one more time and then went out and put almost 70 miles on it last night. She's a runner, runs good.   Came home and did a post-trip, post-mortem. The underside is dry *except* for where the last owner RTV'd the snow out of the intersection of the timing cover and oil pan. He said he had replaced the timing cover seal, but, my dude had clearly done it incorrectly and then tried to hold back fate with black RTV. Never works.   Yesterday morning I replaced the broken driver's door mirror. As much as I hate cheap Chinese parts, thank goodness for cheap Chinese parts. I think an entire new power mirror assembly cost me like $30, and it works perfectly. Replacement tail lights (faded, and one was busted) ran me about $12/side. I have a door pin kit ready to go in because the driver's door sags just a little and I want to fix that because there's nothing sadder than a saggy door.   I don't know what's next for this rig. Half of me wants to take some nice photos (there's a park nearby with a HUGE American Flag that always seems to be catching wind) and throw it up on CL/Marketplace for a couple grand and see if it flies. The other half of me... I've got a sweet running S10 Blazer that's been keeping my mind off of whatever I'm going through right now, and it's bringing some joy, and is cheaper than therapy. Maybe I'll keep it around for a little while. However, this is my 5th vehicle, just for me. 4 is really my limit, but they are not junk, so need very little attention. I don't know...there's a point where it's just too much and I don't see owning this truck long term. But I solved its major problem, got it running, so I'm going to stick a feather in my cap for now.   Sometimes we just need to get our hands dirty and fix something in the physical world to gain some satisfaction.
