I really am looking for someone in the nj/ny/pa area that can tune this truck to remove the speed limiter I'm sitting on a set of headers and exhaust and a afe intake I want to install them the same time I get tune done let me know of anybody that you know
Good luck. GM has these computers all locked up. If anyone is tuning it will cost plenty of cash. Thats all I heard.
    • It was never mandated.  Ever.    Automakers were incentivized to install it by getting CAFE credits to help with their vehicle fleet fuel economy scores.  They were being handed money/CAFE credits to install it.  Which is NOT a mandate.       The current admin removed the incentives that were behind them installing it.
    • I went another direction after losing a trailer tire, thanks to not being able to access air at ANY of the 5 gas stations and garages I stopped at prior, with a Toyota Tacoma onboard, 50 miles from the Canadian border. They were either out of order, access was blocked, or the hose a few feet too short and I couldn't get any closer without risking damage to someone's property.   https://postimg.cc/gallery/X5QJ55w
