Haven't been able to find a post on this topic so please point me in the right place if so. I want to level my 21 Z71 an am debating front vs reverse level.
This is mostly for aesthetics but would like to maintain as much ride quality and durability as possible. Haven't seen very many setups of an "offroad" looking reverse level but that seems like the easiest/lowest risk option. Don't love the idea of just a spacer level but have heard control arms can alleviate some risk or going with a coilover setup is better as well. Never have modified any of my truck's suspension before so open to any and all advice, input, etc. as to what is a recommended option. I'd like to keep it reasonable as well as far as cost.
Thanks!
Keep in mind that the front suspensions on these trucks are the same between the regular and TB/AT4 trucks. Only difference is the struts and CV shafts.
That means you could go up 2” and still be the same as a factory Trail Boss in terms if geometry and alignment.
    zibzer2
    zibzer2
  • Who's Online   5 Members, 0 Anonymous, 839 Guests (See full list)
    • 2023 GMC 3500 HD, SLE, 6.6L Gas, 4x4, 6 Spd Options:  SLE Convenience Package; Driver Alert Package 1; Spray on Bedliner; X31 Off Road Package; TRAILERING MIRRORS, HEATED POWER -ADJUSTABLE, AUTO DIMMING, WITH TURN INDICATORS WHEELHOUSE LINERS, REAR INC. REAR AXLE - 3.73 RATIO INC. GVWR, 11,350 LBS. (5148 KG) INC. FRONT AND REAR PARK ASSIST, INC. ULTRASONIC     I have been launching my new boat and noticed some things related to the parking brake.. I usually set the parking brake (habit) when on flat ground for typical driving.    When backed down on the launch ramp to launch the boat and I place gear selector into Park, the parking brake activates automatically. My second nature is to set parking brake manually and noticed I was turing the parking brake off.  The parking brake appears to be setting itself automatically.   I looked all over my owner's manual and only found references to being on an incline and manually setting parking brake, or at times parking brake will be auto engaged, but nothing specific to my situation.    When is the parking brake automatically engaged?  Under what specific circumstances?  Can the auto set parameters be changed?     I like the auto set feature.  It would be nice if always engaged when shifted into Park and released when shifted out of Park (like my wifes 2025 RAV4).   Thanks!
