Hey, I was wondering if anyone knew where to get custom fit window shades for a 2017 Chevy Silverado 3500. I have kids so I would like sun protection but be able to put the window down. I’m currently using basic kid window shades but I would prefer a cleaner look, similar to the pics attached.
Edited by Barbie
    • when it's greyed out that is it's way of telling you that it's downloading the patch in the background. Eventually it will be fully downloaded and then it will prompt you at ignition shut down to run the update. I highly recommend doing the update once you get home and can run it a few times. I've had several issues with updates not going the first time around and I had to retry the update multiple times in my driveway before it was successful.   Some updates are huge and take awhile to download. You can help it by connecting to your home WiFi and keep the truck on service mode for the ignition and keep it alive for awhile on a battery charger too. There are specs it needs to be in for updating such as a full enough battery charge, no running ignition, etc.
    • I am not techy at all but wondered if you have the truck running but sitting still in park as some functions gray out as soon as the truck is moving. I believe in the settings for updates you can choose for it NOT to update and I wonder by chance if maybe that was chosen before and now it won't allow you to chose to press update, I think that is back in the settings menu where it has all the items one wants on or off etc. Also I assume you have a wifi connection and checked that it has some signal strength, not that it would have anything to do with the grayed out updates choice in that case. What I am thinking out loud of here may be be of no value but thought I would suggest it, sometimes it can be the simplest thing that resolves an issue.
