i traded in my 2017 Silverado for a 2020 Silverado but i kept the factory Chevrolet 22” black wheels.  The front calipers are larger on the new truck and i need to know what size spacer to buy for the 22” wheels to clear the calipers.  it doesn’t appear to need much but i don’t want wheels to stick out too far.  is .25” enough?  or do i need to go with .50” or larger?
I’m pretty sure I read somewhere that 3/8 was recommended. I know I was pretty sad about not being able to swap my ck157’s over when I traded trucks. I just didn’t want to run spacers so I let them go.
