Trailblazer Towing & Mileage...
We made a short road trip over the holiday. Drove about 180 miles, all highway, averaged about 65mph and got a little over 21mpg. Our TBZ has the 3.42 gears and that's the best mileage we've ever gotten so far. Usually it's about 17mpg mixed driving conditions.
On the way back I towed an open utility trailer with an ATV on it. The total weight was only 1600lbs and the Trailblazer towed it great. It dropped out of OD quickly on every hill but maintained 65mph easily in 3rd and sometimes dropped to 2nd on longer hills. No need to manually shift out of OD as the transmission didn't seem to gear hunt too badly. I've towed stuff around locally on short trips but this is the first "longer" trip I've used it for towing.
The mileage on the return trip dropped to about 16mpg due to the trailer. Still not too bad. I always thought our TBZ felt weak at low rpms (due to the 3.42 gears IMO), but the trailer didn't seem to have much negative effect on acceleration from stop so that's good. It does reinforces my opinion that you need the 3.72 or even the 4.10 gears if you do alot of towing with one but the 3.42 is fine for lighter trailers. We went ahead and got the 3.42 because I have the F250 for towing our heavier trailer.
Anybody else around here towing with their Trailblazer/Envoy etc? If so how much, what kind of performance and what gears? Just curious.
I pulled a 68 Firebird on a 16 ft flat trailer with the 2002 Trailblazer 4.2L w/ 3.42 gears I was impressed at how it handled the weight around 5,500 lbs I pulled in third gear OD ran RPM's too low. The 3.73 gears would have been much better though. I traded the 02 in for th 03 EXT 5.3L it has 3.73 gears and I pulled a uhaul 6x12 with around 3200 lbs combined weight for 700 miles and it was really good on the interstate @75 to 80 mph in OD but on the 2lane hilly curvy hwy's where the limit is 55 mph it needed to be in third gear instead of OD because the rpm's were too low for pulling. I still got around 15 mpg on the interestate pulling.
I pull our 18' Mariah skiboat often, averaging 2 hour trips and longest being 6 hours through the foothills of Kentucky and Tennessee. 4.2L with 3.42 gears and it did great. Can't tow in OD like the manual suggests, temp raised too much. 3rd was just fine, didn't even notice the 3K lbs in the mountains.
Good info guys. I'm glad to hear you guys are having such nice results with the 3.42 gears.
I doubt I'll tow anything much heavier with mine. My wife doesn't want me to put a brake controller in it! :confused: But that's what we have the pickup for.
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
    • Melling I believe is/was the OEM on the lifters who explored this problem some years ago. The white paper they generated on the topic indicated two items of note when I read it. 1.) They only fail on the switch. Prevent the switch, prevent the failure. 2.) The majority fail due to deposits messing up the timing of that switch. Anyway that's what I got from it.    Mine have always been active, 195K+ now, and my oil maintenance is surgically clean.    Of course this assumes good parts. That is no heat treat issue or machining flaws. I get comfortable that these issues are in the rearview mirror by about 30K. IMHO naturally.
    • Yes, the key seems to be with the half tons that if it has the Z71, then it definitely has the two speed. What got me was that the two speed AND the lower geared towing package option could not be chosen together the last few years unless it was mated up to the 6.2. Want the 3.0 duramax and 3.73 tow gears ... nope, can't get the two speed transfer case ( neighbor son realized that after he had bought his used 3.0 half ton .. where the frick is the low range ? ! ).    I am still unsure which truck series, the half ton or the HD truck that the original poster is referring to for sure other than yes his question is in the HD section of this forum but that doesn't guarantee the question got asked in the right section.
