hello all, i have a 2020 gmc 1500 sierra elevation 2.7 l4. has anybody used the trailer tps on a set of winter swap tires and wheels. or do you know if it would work?  thanks big brown
As long as you get the correct sensor frequency you will be good.
2020 should be using the newer 433 Mhz ones.
If you want to do the wheel swaps (or do wheel rotations) yourself, spend $20 and get a tpms teach tool.  The method of changing the air pressure in the tire to teach the locations no longer works on these trucks.
(lots of dealers will walk around the truck and do the teach for you in their service receiving area -- free of charge and without appointment)
You can get sensor from you dealers parts department or almost any tire shop or online.
Some of the aftermarket ones are dual frequency (315Mhz and 433 Mhz)
Edited by redwngr
thanks, the truck came with an extra set of 4 sensors for a trailer. will these work on the winter wheels? i could not find the mhz listed for these sensors. thanks for any info.
    overspeed
    overspeed
  • Who's Online   1 Member, 0 Anonymous, 278 Guests (See full list)
