I'm having issues with my check engine light coming on sometimes when my truck is at an idle. When I start to drive it goes away. I check the OBD1 code and it reads 35. I reset the light and after a drive cycle even if the light doesn't come on I check it  and it still reads code 35. Anyone have any suggestions?
Thanks
