I need help! My transmission went out and took my rear diff with it (or maybe it was the other way around?) It happened 4 years ago and due to budget issues we didn't fix her right away. We got a rear diff at our local PickNPull and had the transmission rebuilt but the diff we got at PNP has a different ratio and I'm not sure how to figure out the correct rear diff number. She's a long bed extra cab with the special tow package and a 5.7L V8. I'm the second owner. Is there a number hidden in the VIN?
Edited by LittlSuzi
Adding photos of original info
The information is right there in the RPO code list in the glove box.
You have a GT4 and G80. That means the factory diff had a 3.73 rear end with a Factory G80 positraction diff.
To figure out the gear ratio of the used diff you can remove the cover and count the teeth of the gears. Or put a piece of tape on the tire, rotate the driveshaft by hand with the rear end on jack stands and count how many turns it takes to do a full 360. I believe I am explaining that right, you can youtube a video on it as well.
Thanks! To be honest I should have read other posts and done more googling first I think I did find everything we need but thanks for the info anyway. I appreciate it!
3 years ago i had same problem , my rear diff was soo worn out the teeth on both gears were sharp , my rear diff bound up and took out my transfer case , driveline , and trans adapter, i was in alabama at the time , cost almost 3000 to get it back on road to get it home and finish repairs
