Anyone have these wheels in black?   I'm thinking of painting them.  I've tried Google images but can't seem to find  any on a truck.  I'm curious what it would look like.
Welcome to the site.
Something like this, maybe:
Those would probably look good, but I'm hoping for a nice blackout look...for now...with what I got, then go for Fuel Contra wheels when the tires wear out.
You could also, go for this look. Stock Chevy wheels from the dealer in black.
Edited by MikeBMW
    Policeoff01
    Policeoff01
  • Who's Online   4 Members, 1 Anonymous, 745 Guests (See full list)
    • On 2021 3500hd it consistently sets automatically when selecting park if the incline/decline is above a certain angle.
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
