So I'm having an issue with the lights in my 2005 GMC Sierra 1500. The dash lights, heated seat lights and even the headlights will flicker on and off. Sometimes if you hit a bump it will make them go off or come back on. Every once in a while the headlights will flip off and then right back on. But... the gauges work, the window, lock, and heated seat switches work even when the lights don't. The switches on the steering wheel work and the radio dials, heater switches on the dash... everything still works. The only things affected are the lights. You can push the dimmer dial and even right above the dimmer dial and the lights will come back on. And sometimes you can smack the dash and they'll come back on. Lots of info but I'm hoping someone can help me figure this out. Oh, and the service engine light never goes off even when the other things do. Any thoughts??
Sounds like loose wiring plugs or bad grounds. You can find where the grounds are located using the GM service manual; it may not be in the general one, it's prolly in an electrical systems book. It's prolly on line like most everything is. On my 06avalanche there are /is a grounding point under the driver's feet (not under the carpet) near the frame, it's a bolt with a few wires under it. Remove the bolt, wire brush the wire ends, make sure the metal under the bolt is clean, apply some die electric grease (sparingly) to the wire terminals to stop corrosion and re-install the wires and bolt. Check your issues. if fixed carry on, if not look for more bad grounds/loose plugs.
Richard Wysong, there was one time the dash got so hot it almost burned my finger. And I have noticed it seems to be worse when we use the heater. Do you know where I can find the connector or what the official name of the connector would be in case I need to find a diagram online?
Dna9656 thanks. I'll for sure give this tip a try. It can't hurt to clean it up. Electronic stuff is what confuses me the most. Also, I forgot to mention, the four wheel drive isn't working either. My husband thinks it may be in the switch and that it's related to the light problem.
the connector is on the back of the light switch. sounds like you may have some disconnected duct work for the heater behind the dash. scan tool may be able to help with 4wd problem
    ShowMeShooter1332
    ShowMeShooter1332
  • Who's Online   4 Members, 1 Anonymous, 4,881 Guests (See full list)
    • Well....I've done my first intake gasket. Probably wrong, but...we'll see?   Ultra black on the china walls and 1/4" up onto the sides of the intake gaskets. Permatex High Tack (couldn't find Gaskachinch) on the head side of the intake gasket. I read wrong and it says you're supposed to put it on the mating surface of the head, not the gasket. Hoping it's like a PB&J sandwich where it doesn't matter what side the PB goes on so long as there's jelly. That crap is messy/sticky and I got a dab or two on the intake port openings, tried to wipe it off. Hopefully it won't be a big deal and will only aid in sealing.   Per instructions I left the intake (top side) of the gasket dry except for a light smear of RTV around the coolant ports. Wiggling the intake in there was a bear but I had help to free me of surrounding wiring/stuff but I was basically able to set it straight down lined up with the bolt holes.   I did not think to wait until the RTV skinned over but there probably was 5-10 minutes while it sat before installing the intake.   Bolts finger tight first. Then, followed the Chilton's manual pattern to snug them to 15 lb-ft.   Waited a little over an hour, and then did the final torque in sequence again to 35 lb-ft.   Yesterday I replaced the fuel pressure regulator and got my new "nut and bolt kit" (fuel lines) installed. Damn GM used security torx on the spider, which I don't have, so I got scammed at the local HW store for an off-brand security Torx bit set.   The new driver's door mirror arrived yesterday, so, there's a chance this thing could be running and road legal tomorrow? I don't want to get my hopes up.   This will be my first time stabbing a distributor, too. Although, lucky me, someone else marked the old distributor for removal previously, I did see that. (Someone's been here before!!). Engine is still at TDC so it *should* be just a matter of transferring the mark to the new dizzy and rotating it into place.
    • He has his dad’s newer truck he’s put away. He has several old cars he rotates between him and his family. I’ve seen a restored square body and a SS Chevy truck he’s sometimes drives. He did raffle off a new suburban recently. As much as he is watched if he drove new stuff as a rule we’d know it. It would be fine by me. I don’t care what people prefer. I got one more new one in me. I’d rather my wife get one. I can’t get her out of the Genesis. Don’t tell anyone. I want her to get an electric truck. I want to put a generator in the back. Just because. She hasn’t bit yet.
    • Yes, you must have seen my thread on the Blazer. HOT GARBAGE, but I love them anyway. I'm convinced every car guy has a soft sport for an S/T series somewheres. Probably even a Panther too, if I'm being an honest car guy. That doesn't mean they aren't junk. And they definitely don't get better with age. I sometimes play with old cars, but that's by choice. I don't rely on them and they aren't my everyday fleet.   Derek plays the common man on Youtube and that's no doubt where he started. Now he has Youtube money (and Motortrend, etc). You think his crews and his wife ride around in old beaters when they're chasing him and his wrecks across the country? No he's got newer and nicer stuff for that, you'll see glimpses of it in the footage.
    • You refuse to own anything made in this century yet you reportedly own... a 2007 Silverado, which is now almost 20 years old. The dissonance.... turn up your hearing aid?   You clearly don't understand the government contracting process, brother. We send people to die on front lines, keep the public safe, and make people's husbands, wives, children enter burning buildings with equipment from .....wait for it.....   ...the lowest bidder....   Just because something is used for a long time doesn't mean it's good. But it might be cheap and plentiful.   Please, continue to whine about new trucks in a thread dedicated to new trucks, which you've said you'll never own. We get it. Go tell everyone how you're stuck in time on a Panther forum. I mean, Jesus, an 86 isn't even one of the good Panthers.
    • It really is comical when people don’t agree or see the reason some people prefer the older vehicles. They become condescending. All the while they may be busting their knuckles on old vehicles. I have found memories of swapping out engines in my old GM cars in a weekend without much hassle. Unlike today. One wrong move a computer will shut you down. Even on something as easy as a brake job. There’s a pretty comical YouTuber called the car wizard. A garage owner who puts it all in perspective. Another Vicegrip garage that’s shows just how tough the old stuff is.
