I have 2001 Chevy Silverado 1500 having trouble trying to find the issue my truck won’t go in “D” and “3”  but goes in “R” and 1-2  changed out the AB shift selinoids and also replaced the speed sensor any help??? Thank u:)
  • 3 weeks later...
