I’ve been dealing with this issue for a while now (2 winters), and could really use some help. When I start the truck in cold weather it makes an awful metallic rattle. It’s noticeable from inside the house, so not quiet at all. I can’t seem to pinpoint where it’s coming from, although it sounds like a heat shield (I’ve checked them). In the summer I have zero issues, just when the weather hits below 40 degrees or so.  Anyone else dealt with this?
I believe it's the heat shield above the muffler.
I have this issue too but only when I pull away from my driveway when it's cold. Summer and winter
I appreciate the feedback.  I'll check it again this evening.
    contrabombarde
    contrabombarde
  • Who's Online   1 Member, 0 Anonymous, 897 Guests (See full list)
    • I'm sure if you went to a junkyard where you go in and pull the part off the truck yourself, not a used part place where they do it for you, you can get that part on it's own.  Depending on if and what else you would be buying, and time of day, they might even just skip over adding it as a item to the bill.
