I have a 2011 chevy 2500hd 6.0 just got new tires and now it sounds like the truck is whining and howling when going down the road whine sound when accelerating and like a deep howling during deceleration.
It's not a tire howl. I'm going to try and post a video it sounds like it's right below the cab.
Edit:
Hmm. Strange.
I would try to isolate it by eliminating the symptoms. Under what condition does the sound go away?
Try driving it in 4x4 mode.
Try shifting to neutral
Try shutting the engine off and coasting
Try higher RPM ranges, by selecting a lower gear
Try compression braking
Try it in 4x4 low range
Might want to shake down the whole rig. CV axles, drive shafts, front hubs, rear outer axle bearings, engine fan clutch, etc.
You could also check the level and condition of your diffs, T-case, etc.
If you put the rear axle on jack stands, does it still make the sound?
If you put all 4 corners on jack stands, and run it in 4x4, does it still make the sound?
When your under the rig with a mechanics stethoscope listening for stuff, the sound you really don't want to hear is the automatic locks activating. So if your rig automatically locks the doors when you reach a certain speed, you would want to roll the windows down or turn that function off before you start the engine - if your up on jack stands.
Edited by Supreme Pizza
  • 2 years later...
    ChristopherDobson
    ChristopherDobson
  • Who's Online   4 Members, 0 Anonymous, 1,295 Guests (See full list)
    • This is interesting. My quote tagged here is different from my original quote. After I’m driving them longer. That isn’t me. I don’t talk that way. I definitely wouldn’t express myself that way. Interesting.
    • I have the same running boards on my truck and I do agree they are bulky. I also find myself stepping over them when getting in and out of the truck. Besides providing protection to the rocker panels, they aren't very useful.  I will be replacing them soon with the Amp Powersteps.
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
