1 hour ago, jscottl said:
Check out Lonestar Hawaiian on Youtube. He just done his Trail Boss in a satin black/gloss carbon fiber. Looked pretty good done in a two tone.
Will do, thanks man
On 12/16/2021 at 9:34 PM, Luis A. said:
Hmmmm I wonder if there is a way to photoshop that
someone with some talents in that field, shouldn't be a problem
    • On 2021 3500hd it consistently sets automatically when selecting park if the incline/decline is above a certain angle.
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
