Just bought this last week and after a few rainy days, the service 4WD lndicator light came on. The SUV still shifts from 2WD to 4WD, but the service light turns on periodically. Looking for any suggestions.
I would suspect that there is something wrong... HA !
No, seriously though - it may be an issue with the grounds, or the encoder motor itself.
Both are pretty common.
  • Haha 1
Welcome to the site.
Maybe call your local dealer about this TSB:
MC-10174073-9999.pdf
