Ok so I disconnected my battery ground a few weeks ago to work on my alternator and since then the radio won't work. Turns out the ignition switched wire has no power no matter the ignition position. The constant supply has power. All fuses check out good. All other accessories work fine. Any ideas where to start?
I'd start at the Ground wire you disconnected, make sure it's a good (clean and tight) connection) connection and that the cable will carry the load, some may tell you to go ahead and replace the ground cable. If that checks ok start with the  ignition SWITCH, not the lock, the SWITCH. Get a circuit diagram and a test light or Volt, Ohm Meter (VOM) Test lights are operated with one hand, a VOM that's 2 hands. Read the diagram, figure out what's supposed to have voltage and what's not, trace it out to the beginning of the problem, it may be the Ignition Switch (if you're very lucky) but it prolly isn't.
You know how the radio stays on after you turn off the engine (an unnecessary feature IMHO) until you open a door or the timer runs out? Well I got ONE door that turns off the radio now, the RT. Rear door. I think there is a lever not moving in the door latch(es) as it was only ONE door last summer, it was the driver's door. I replaced the latch/switch assembly and still the radio plays when the door is opened. I thought in that case there is a relay that's not operating, but now it's multiple doors. It'll have to keep til it gets warm again, I'm not worrying about that when it's 21 degrees outside.
Ok I'll start at the switch even though I don't suspect that as everything but the radio is working. The retained accessory power is working as it should,like the windows and the dash lights. Could it be that relay would have gone only partially bad so that only the radio wouldn't work? Any thoughts?
    ballencd
    ballencd
  • Who's Online   6 Members, 0 Anonymous, 634 Guests (See full list)
    • Brought my 2015 Colorado into the dealership to check my touch screen issues, had that ghost touch thing happening. They said I needed a new touch screen and they could either order me one for $500. The lady at the service deck was nice enough to tell me I could order a touch screen online for less, she did stipulate that the touch screen had to be factory OEM, you can't pair an aftermarket screen to my radio seeing it was 2015, it had to be a GM factory OEM only. I found a few on Amazon and Ebay by the numbers on the back of the old screen, DJ080PA-01A GM# 22740886, Some said "OEM" in the description and others just said "Replacement". Would a replacement be the same as a OEM as long as it had the same numbers on the back of the screen? In some of the descriptions they also show different brand names but same numbers, is that an issue?
    • I have both but typically use the 4 legged walker (wheels on front, ski's on back).   The four wheeler is starting to be used on "longer" outdoor walks.  The 4 legged walker is particularly helpful in practicing good walking posture.  Both of my knees are at different stages of recovery and I'm trying to not develop poor habits.  I can actually manage with a cane but it's very difficult not to favor one leg over the other.  My PT recommends I continue with my 4 legged walker for a while.  Yesterday was four weeks since my last knee replacement and I'm excited about my progress to date.  It has been a hell of a rough journey so far but it is exciting to witness  systematic and continuous improvement.  I went for years watching the decline of my "mobility".  It seems that everyday now I am alerting my wife to something I can do now that I couldn't a day or two ago!  I encourage anyone facing the prospect of knee replacement to share any concerns with others who have had the surgery.  It isn't an instant fix but rather is a considerable amount of short term pain for long term gain.  Recovery time and pain levels vary for individuals post surgery but the end results are typically very positive and I've never encountered anyone regretting having had the surgery.
    • The lifter issue can be dealt with by shorter oil changes and quality oil IMO.
    • Got heavy rain, hail and light rain yesterday.
    • I'm putting in an A-pillar pod/gauges, and I'm asking if anybody can identify a (preferably) fuse for a switched power and illumination circuit on the driver's side interior fuse panel. Offhand, everything I checked with a test light was constant-hot, and I'd much rather uses a piggyback fuse. I can certainly find a wire, but I'd rather not half-tap.   Thanks in advance for any help.
