I recently purchased a 2015 Silverado and upon driving it off the lot I realized that neither my front nor my back parking sensor's work and when I put the truck in reverse it shows the lines in which direction you are going but the camera is blank.  I've tried to locate fuses for it with no luck any help would be much appreciated thank you.
Welcome to the site.
Not sure about the sensors, but would check your connections on the HMI module that is behind your glove box. It controls most of the features of your radio/camera for that problem.
ck to see if the sensors are turned off. Here's video for the setting.
12 minutes ago, Jeff blueladderconstructio said:
I did that... still no luck.
Check fuse #27 in the passenger side box. It says that it also controls your USB ports. Maybe plug something in to see if they work.
14 minutes ago, Jeff blueladderconstructio said:
Jim. I Also tried that to. Still nothing...
Can you scan for this DTC U0159 code? There was a TSB for the model years 14 - 16 having problems with the parking sensors and needing to be replaced with the new design that started in model year 2016 - 2017. PIT5507E
    sqidget
    sqidget
  • Who's Online   2 Members, 0 Anonymous, 739 Guests (See full list)
