I’m having a problem with my power windows. the driver side and both rear windows stopped working at the same time the passenger window still works but only the passenger can work it i already changed the driver side switches and still nothing. Anyone have an idea on what it could be? Tia
I'd look into a wiring issue, possibly the wires going through the door harness.
Is it just the master switch that doesn't work or do the switches on the other doors not work either?
  • 6 months later...
I have the exact same issue. Rear window switches do not work now as well. Replaced the master switch. Didnt find any wires broken from what i could see and didnt see any fuses that needed replaced. Im guessing its a wire i can see thats broken somewhere.
    • My brother has an Escalade. The warranty has expired so he told his wife to go to the Valvoline quick lube he uses some times. They told her if her car was a 2020 and newer 6.2 engine they wouldn’t touch it. Hers is a 2019, so they did the oil change.
