New to page thanks for any advise. 97 Sierra 4wd. Transfercase motor just clicks (even with ignition off) lights flash then stay on 4wd low. Never engages. Has new tccm, encoder/motor, switch on dash, front diff acuator, all fluids a full. Any ideas?
Edited by Debeard77
   Hi.
Can you provide more specific information?
How did this problem come about?
Can you shift between different ranges at all?
What do you mean that it clicks even when ignition is off? What makes it click? Pressing buttons?
Did this problem happen before you replaced all that stuff, or did it happen after you replaced all the parts?
Just got the truck not long ago was doing before parts. With the key out the transfer case motor will  keep "clicking" like its trying to shift the case..there is no 4wd at all with not go in low or high. Have to take the fuse out or will just go and go.  Could the case be broke stuck in 2wd?
Edited by Debeard77
Also, when you shift the transfer case, are you following the instructions in the owners manual?
Simply pressing the tranfer case shift buttons is not the correct procedure. There are other necessary steps that must be taken if you want to change the tranfer case settings.
try disconnecting the battery. sometimes that works to reset the system. the only time I have seen that happen was on a 2000 Blazer with a bad battery. new battery and the system reset
9 minutes ago, Debeard77 said:
Just changed it no flakes. What steps are u speaking of?
I cant tell you what your vehicle needs. Here is what my rig wants, in order to shift from 4L to 2H:
1)  Engine running.
2) Transmission in neutral.
3) Vehicle rolling forward or backwards at 1 or 2 MPH.
4) Press transfer case shift button.
Your rig might want a different procedure.
if that doesn't work remove the motor from the tc and see if you can shift it manually. if you can't you found the problem
Ya, that's a good idea. At least he could get it into 2H so that it can be driven.
It may shift by hand more easily of the transmission is in neutral. (might want to chalk the tires).
I don't know if its possible to install the motor incorrectly but thats a possibility as well
Pulled the encoder motor of transfercase I can shift it manually. Does anyone know how hard it should be to shift? Seemed like it took a lot of force to shift it.
it may be normal with out the truck rolling. with the encoder motor off but connected does it work when you try different modes? does it still click when shut off? if it seems to be working properly manually put it in 2hi and reinstall the motor and see if it works
the manual shift tcs sometimes take a good tug to change modes so as long as it does shift its probably ok.
    MASONV88888888
    MASONV88888888
  • Who's Online   4 Members, 0 Anonymous, 1,009 Guests (See full list)
    • https://www.msn.com/en-us/autos/news/fuel-economy-stickers-don-t-tell-the-whole-story-aaa-data-reveals-why/ar-AA26ocHk?ocid=winp2fptaskbarhover&cvid=6a4122ea3dae47e5b8dfbed5d4fd3d55&cvpid=648f6b4fc2fa4eddb4c12893aeb957ed&ei=59
    • What’s missing in all this is patience and investment in the future. Buy a 170K starter home. Ten years later sell it invest in a more expensive home. Eventually you’ll have a 600K home and pay starter home payments. Buy a starter car. Maintain it well. Save the payments after it’s payed for then buy an expensive car if you desire. Buy a tumbler make your own coffee, pack your lunch. Cook your own dinner. Most importantly take care of your car.
    • People mislead themselves. Statistics are highly useful indicators.   Here's the tie-in to this thread. If an oil sample tests shows a wear indicator of 7 using cheaper ACDelco oil, and a wear indicator of 2 (lower = less wear) using a particular brand of Mobil oil, and wear has a linear relationship with engine lifespan, anyone could assume that Mobil is reducing wear by more than 50% (let's just say a 200% reduction for you red state people trying hard to do math) which leads to increasing engine life by 2x. Perhaps, in a vacuum, by itself, when dreamed by AI.   Yeah?! That's what the statistic is saying, isn't it?   No, it isn't. It didn't come out and say engine life is doubled. That's a very bad assumption, and a case of severe myopia by assuming something potentially untrue about the only data point in focus.   Average cost of a new car is 50k. You bet it is.   The median cost of a new car is more like 35k. Expensive cars are skewing the perception that "average" now means a $50k price of entry for a very average automobile. And that's not true. People who don't understand statistics twist the living heck out of them to mean all sorts of things they don't actually mean.   "Average" new car payment is $1000/month. Yep, it is. And in that number are all the $35k new car buyers who bring significant equity, and the $25k new car buyers who finance the car for a month just to get a rebate, and then pay it off. Know what isn't in that number? All the payments made by people who don't finance a car.   Picking one's own data point (don't have a car payment, never paid $50k for a new vehicle, my house cost $170k, I afforded a middle class lifestyle on $4.50/hr) is just a data point. Just like earning $25/hr in an area where the median home price is almost $1 Million is a data point. In fact, it's a lot of data points given that 80% of the US population lives in/around major cities. They're not idiots; the vast majority of them do it to make a living because that's where the big money is.   The highs have become higher, lows have become lower, and how your personal mileage varies is not truth for an entire country. At the same time you can't NOT acknowledge the data. While it doesn't paint YOUR personal picture, it certainly tints the reality that you also live in, as does your single data point.
    • Glad you had success with it. I did as well, but about 5-6 months later it returned. Tried again, same result. This was after the dealer made several attempts and never even got it to slow down.
    • 3.15 Kroger’s in Montgomery Tx
