Hello guys I have a 2022 Sierra 1500 ATX4 limited and I installed and K$N cold intake air system, and now I am getting a “ check engine air filter system” does anyone know how to reset this on a 2022? Or anyone have a idea to remove this?
  • 3 months later...
When you installed the K&N , did you remove the batt. cable ?? Remove the batt. cable, wait about 10 min, reinstalled should clear it.
    Frank V
    Frank V
  • Who's Online   7 Members, 0 Anonymous, 1,225 Guests (See full list)
